zabbix 1.6.4 + pg problem: undefined reference to `PQexec'
  • noname
    • Jan 2008
    • 120
    Configure successfully:
    ./configure --enable-server --with-pgsql --with-net-snmp --with-libcurl --prefix=/opt/zabbix
    Configuration:
    Detected OS: linux-gnu
    Install path: /opt/zabbix
    Compilation arch: linux
    Compiler: gcc
    Compiler flags: -g -O2 -I/usr/include/pgsql -I/usr/include/rpm -I/usr/include/gdbm -I/usr/lib/perl5/i386-linux/CORE -I. -I/usr/include
    Enable server: yes
    With database: PostgreSQL
    WEB Monitoring via: cURL
    Native Jabber: no
    SNMP: net-snmp
    IPMI: no
    Linker flags: -L/usr/lib -lpq -lcurl -lcrypto -lnetsnmp -lcrypto -lm -lcrypto -lwrap -lcrypto -lcrypto -lnetsnmp -lcrypto -lm -lcrypto -lwrap -lcrypto
    Libraries: -lm -lresolv -lcurl -lnetsnmp
    Enable proxy: no
    Enable agent: no
    LDAP support: no
    IPv6 support: no
    * Now run 'make install' *
    * Thank you for using ZABBIX! *
    * <http://www.zabbix.com> *
    Make install failed:
    gcc -DZABBIX_DAEMON -g -O2 -I/usr/include/pgsql -I/usr/include/rpm -I/usr/include/gdbm -I/usr/lib/perl5/i386-linux/CORE -I. -I/usr/include -L/usr/lib -lpq -lcurl -lcrypto -lnetsnmp -lcrypto -lm -lcrypto -lwrap -lcrypto -lcrypto -lnetsnmp -lcrypto -lm -lcrypto -lwrap -lcrypto -o zabbix_server zabbix_server-actions.o zabbix_server-operations.o zabbix_server-events.o zabbix_server-zlog.o zabbix_server-server.o alerter/libzbxalerter.a dbsyncer/libzbxdbsyncer.a discoverer/libzbxdiscoverer.a pinger/libzbxpinger.a poller/libzbxpoller.a housekeeper/libzbxhousekeeper.a timer/libzbxtimer.a trapper/libzbxtrapper.a nodewatcher/libzbxnodewatcher.a utils/libzbxutils.a httppoller/libzbxhttppoller.a watchdog/libzbxwatchdog.a escalator/libzbxescalator.a ../../src/libs/zbxsysinfo/libzbxserversysinfo.a ../../src/libs/zbxsysinfo/linux/libspecsysinfo.a ../../src/libs/zbxsysinfo/common/libcommonsysinfo.a ../../src/libs/zbxsysinfo/simple/libsimplesysinfo.a ../../src/libs/zbxlog/libzbxlog.a ../../src/libs/zbxnix/libzbxnix.a ../../src/libs/zbxsys/libzbxsys.a ../../src/libs/zbxconf/libzbxconf.a ../../src/libs/zbxemail/libzbxemail.a ../../src/libs/zbxsms/libzbxsms.a ../../src/libs/zbxdbhigh/libzbxdbhigh.a ../../src/libs/zbxdb/libzbxdb.a ../../src/libs/zbxdbcache/libzbxdbcache.a ../../src/libs/zbxcommon/libzbxcommon.a ../../src/libs/zbxcrypto/libzbxcrypto.a ../../src/libs/zbxcomms/libzbxcomms.a ../../src/libs/zbxjson/libzbxjson.a ../../src/libs/zbxserver/libzbxserver.a ../../src/libs/zbxicmpping/libzbxicmpping.a -lcurl -lnetsnmp -lm -lresolv
    ../../src/libs/zbxdb/libzbxdb.a(db.o): In function `zbx_db_vselect':
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:724: undefined reference to `PQexec'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:733: undefined reference to `PQresultStatus'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:744: undefined reference to `PQntuples'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:735: undefined reference to `PQresultErrorMessage'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:735: undefined reference to `PQresultStatus'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:735: undefined reference to `PQresStatus'
    ../../src/libs/zbxdb/libzbxdb.a(db.o): In function `zbx_db_fetch':
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:604: undefined reference to `PQnfields'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:611: undefined reference to `PQgetisnull'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:617: undefined reference to `PQgetvalue'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:618: undefined reference to `PQftype'
    ../../src/libs/zbxdb/libzbxdb.a(db.o): In function `PG_DBfree_result':
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:560: undefined reference to `PQclear'
    ../../src/libs/zbxdb/libzbxdb.a(db.o): In function `zbx_db_insert_id':
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:817: undefined reference to `PQgetvalue'
    ../../src/libs/zbxdb/libzbxdb.a(db.o): In function `zbx_db_vexecute':
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:467: undefined reference to `PQexec'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:474: undefined reference to `PQresultStatus'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:476: undefined reference to `PQresultErrorMessage'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:476: undefined reference to `PQresultStatus'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:476: undefined reference to `PQresStatus'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:488: undefined reference to `PQclear'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:486: undefined reference to `PQntuples'
    ../../src/libs/zbxdb/libzbxdb.a(db.o): In function `zbx_db_connect':
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:128: undefined reference to `PQsetdbLogin'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:133: undefined reference to `PQstatus'
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:135: undefined reference to `PQerrorMessage'
    ../../src/libs/zbxdb/libzbxdb.a(db.o): In function `zbx_db_close':
    /opt/zabbix-1.6.4/src/libs/zbxdb/db.c:53: undefined reference to `PQfinish'
    collect2: выполнение ld завершилось с кодом возврата 1
    make[3]: *** [zabbix_server] Ошибка 1
    make[3]: Leaving directory `/opt/zabbix-1.6.4/src/zabbix_server'
    make[2]: *** [install-recursive] Ошибка 1
    make[2]: Leaving directory `/opt/zabbix-1.6.4/src/zabbix_server'
    make[1]: *** [install-recursive] Ошибка 1
    make[1]: Leaving directory `/opt/zabbix-1.6.4/src'
    make: *** [install-recursive] Ошибка 1
    What's wrong?
  • noname
    • Jan 2008
    • 120
    strange results?
    But this command work correctly:
    gcc -DZABBIX_DAEMON -g -O2 -I/usr/include/pgsql -I/usr/include/rpm -I/usr/include/gdbm -I/usr/lib/perl5/i386-linux/CORE -I. -I/usr/include -L/usr/lib -lpq -lcurl -lcrypto -lnetsnmp -lcrypto -lm -lcrypto -lwrap -lcrypto -lcrypto -lnetsnmp -lcrypto -lm -lcrypto -lwrap -lcrypto -o zabbix_server zabbix_server-actions.o zabbix_server-operations.o zabbix_server-events.o zabbix_server-zlog.o zabbix_server-server.o alerter/libzbxalerter.a dbsyncer/libzbxdbsyncer.a discoverer/libzbxdiscoverer.a pinger/libzbxpinger.a poller/libzbxpoller.a housekeeper/libzbxhousekeeper.a timer/libzbxtimer.a trapper/libzbxtrapper.a nodewatcher/libzbxnodewatcher.a utils/libzbxutils.a httppoller/libzbxhttppoller.a watchdog/libzbxwatchdog.a escalator/libzbxescalator.a ../../src/libs/zbxsysinfo/libzbxserversysinfo.a ../../src/libs/zbxsysinfo/linux/libspecsysinfo.a ../../src/libs/zbxsysinfo/common/libcommonsysinfo.a ../../src/libs/zbxsysinfo/simple/libsimplesysinfo.a ../../src/libs/zbxlog/libzbxlog.a ../../src/libs/zbxnix/libzbxnix.a ../../src/libs/zbxsys/libzbxsys.a ../../src/libs/zbxconf/libzbxconf.a ../../src/libs/zbxemail/libzbxemail.a ../../src/libs/zbxsms/libzbxsms.a ../../src/libs/zbxdbhigh/libzbxdbhigh.a ../../src/libs/zbxdb/libzbxdb.a ../../src/libs/zbxdbcache/libzbxdbcache.a ../../src/libs/zbxcommon/libzbxcommon.a ../../src/libs/zbxcrypto/libzbxcrypto.a ../../src/libs/zbxcomms/libzbxcomms.a ../../src/libs/zbxjson/libzbxjson.a ../../src/libs/zbxserver/libzbxserver.a ../../src/libs/zbxicmpping/libzbxicmpping.a -lcurl -lnetsnmp -lm -lresolv -lpq
    • noname
      • Jan 2008
      • 120
      and solution?
      ./src/zabbix_server/Makefile:
      154 string:
      - LIBS = -lm -lresolv
      + LIBS = -lm -lresolv -lpq
      I don't know why is happening so.
      I would be grateful for the comments.
